| Message |
after doing plenum pull,ecu upgrade,misc.fuel hoses ,gaskets,etc.,getting code 34 on ecu with bouncing idle from 800-900.I found a broken wire on the det. sensor connector so i repaired it and reset the ecu.It started right up and idled perfectly for about 45sec. to 1 min. and went right back to bouncing idle.Then I check the ecu again after clearing the memory and still code 34.It seemed like after ecu reconizes the fault it runs like crap.could have my det sensor gone bad from just sitting still in my garage for 1 month?any help please.
